I did a drawing in ACA2011 sent it to my remote office where I have ACLT for mac 2013 (trial). Worked on the file,
had to explode the couple of walls I was editing, saved as 2011 or 2010 file.
When I open the file in ACA2011 I can not execute the wall tool. This is the message received:
Command: _AecWallAdd Command not allowed because drawing contains objects from a newer version of this application.
The new objects would be lines.
Is this really happening? Is there a fix?
JM
I'm afraid there's no fix. Anytime you open a 2012 (or earlier) version file in a 2013 version product and save it, all AEC content will be updated to the new version. I might note that it was also that way with the last file format change in 2010, and in 2007, and 2004. If you need to continue working on it in 2011 you can do an export to Autocad (instead of saveas), but all of your AEC entities will be exploded.
John
I was afraid of that. It is strange. What AEC content does ACLT produce? Nothing. But it apparently captures the content and holds it captive, huh?
JM
The really disturbing thing is that now back in ACA2011 when opening the file, I cannot even use aec tools, walls, doors nothing.
so not only are the products not compatible, the lesser product (ACLT) has actually ruined an ACA file and disabled
the program.
Why is this a good thing?
If you do an export to Autocad from the 2013 product you shouldn't have any problem using AEC tools in 2012. But it will explode all of your existing AEC content. AEC tools are disabled if there is any newer version content in the file.
John
