Seems like with 2011 my wall cleanup is a bit messy. when i move a vertical wall say- 3ft to the right with a wall perpendicular to it - it extends the vertical wall to where the yield sign shows up because it didn't "cleanup" the T intersetion once the wall is place. DIdn't have this problem in 2010.
why are the odd versions always - well - odd?
I would like to look into this. Would you please do me a favor attaching a drawing showing what you encounter?
Sam
AutoCAD Architecture team
Autodesk, Inc.
Sam -
i could finally get it to replicate. if you look closely by the door and the other perpendicular wall you can see a slight overlap causing the yellow yield signs to show up (not on the pdf). it happened when i tried shifting the walls.
and do you know of any service packs out yet for 2011 architecture? because there's an annoying highlighting issue as well. when the crosshairs go over some items things highlight and don't unhighlight until you physically regen.
thanks,
Heather
Hi Heather,
You will be happy to hear this - the latest AutoCAD Architecture 2011 update 1 is live now:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15756945&linkID=9240658
Hopefully that helps.
Sam
AutoCAD Architecture Team
Autodesk, Inc.
