Does anyone else get these artefacts on their aecElevations? I am constantly deleting them and can't figure out where they come from. They don't seem to be related to any geometry present in the drawing, come from the OOTB elevation tools. I delete them like any other linework created in an aecElevation but of course would prefer they don't appear at all. Once I thought they might come from the survey but no. They always appear in the bottom left hand corner and are below z0. They are like a star burst, lines mostly leading to a point, just lower than the bottom of the model. They will move up in the bottom of the elevation tool is raised but there is no geometry to match. Ive just 'bind'ed the xref and they dont appear on refresh
anyone else notice this?
mmm... I don't use roof slabs and my geometry is so simple but I can't deny I get have small errors at times. Binding the x-ref and seeing them disappear is the first time I've seen any connection at all.
I've had them for years on many different files Dean so I don't believe they are come from geometry especially since they are like nothing I have ever drawn and are random in nature. I will try to post some more samples and a sample file.
You are right, Nathan. Xrefs are definitely a source of the problem. I use a lot of arched openings and windows, and the artifacts in the elevations drive me nuts. I just did a quick test in an existing project on a wall with an arched opening. I have no artifacts when I create the elevation in the construct drawing, but do have artifacts when I create it in the view drawing.
Nathan, I have seen a lot of artifacts, but mostly from curves, and have not seen the lower left occurrence in your png. Odd, however, that I don't have the segmentation in the Construct drawing, but do have it in the View. Since I don't typically do elevations in the construct drawing, I hadn't noticed the difference before.
Nathan,
It appears to be a Model Extents Marker. Don't ask me how to turn it off. I attached a shot of what mine looks like when I get hit with it. If you set the Lower Extension to a bigger value it should move the "artifact" out of the way. I typically use an AEC Polygon Mask to remove linework below slabs and footings so I end up hiding this beast too.
Also, you can improve the artifact by going to the Model Display Representation of the Elevation Line Object and turning off all Components.
Cheers,
Odin Cary
Principal, ARCHIdigm
Thanks Odin, that does sound more like what it is and it's strange that is should appear at all.
I'll try that option to turn all off.
As I have the bottom of elevation at ground level (if ground flat) the artefact generally is shooting into the elevation area so I can't mask and have to edit-delete. Be great to be able to turn it off.
