AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
tutorial help file not showing up
3 REPLIES 3
jimpetty
241 Views, 3 Replies
hey guys, i'm new to Arch 08, and i just downloaded the tutorial .zip from the autodesk website. i've followed the instructions for unzipping the files, as stated in the readme. however, every time i try to unzip the "imperial_chm_and_pdf" folder to the correct spot in the "help" folder, nothing happens. i get a prompt telling me that all files have been unzipped successfully, my path is correct, but when i launch the help menu and navigate to the tutorials, i get the default placeholder page instead!
has anyone else had this happen?
3 REPLIES 3
in reply to: jimpetty
Are you removing the "read only" attribute on the existing CHM file? You
could also try extracting to the desktop and then manually move it to the
correct location.
Jeff Hanson
Autodesk - AEC Technical Publications
Manchester, NH
wrote in message news:5898726@discussion.autodesk.com...
The two default pages with the instructions on how to download the tutorials
come
from two .CHM files in the C:\Program Files\AutoCAD Architecture 2008\Help
directory. The two file names are "ADT_Imperial_Tutorial.chm" and
"ADT_Metric_Tutorial.chm", respectively. The files which are downloaded
that are
supposed to replace those two files are named "aca_Metric_Tutorial.chm" and
"aca_Imperial_Tutorial.chm", respectively. Since the file names are not the
same,
they do not replace the original files. This can easily enough be
accomplished
manually by either renaming or deleting the original .CHM files, and then
changing
the "aca" part of the new file names to "ADT". Once that is done, the
tutorials are
accessed perfectly as they were intended to be.
Credit to Zac Travis of the Autodesk Support Team for the above.
This worked for me so maybe it will for you too.
jimpetty
ah! excellent! thank you.
”Boost
