AutoCAD Architecture General
Member
ghermans
Message 1 of 5 (1,098 Views)
trim wall to roof
1098 Views, 4 Replies
06-06-2011 04:57 AM
I am working in Architecture 2010.  A wall is sticking through the roof and I would like to trim it.  I tried it in several ways but it will not trim.  Can anybody help me in this.
Gunter
Distinguished Mentor
ntellery
Message 2 of 5 (1,095 Views)
Re: trim wall to roof
06-06-2011 06:45 AM in reply to: ghermans
Are you wanting the wall to follow the underside of the roof object? or is your roof slabs?  I think you can project to both in much the same way.
But if your wall top is above the roof bottom then it won't be able to do it.  It effectively needs to be able to extend (project) the wall above the top into the roof so you may need to lower your wall height to be completely lower than the roof.
Then click the wall and Right click. Go to option Roof/Floor Line and modify roof line and then select your roof (works with stairs as well).  Your command line will show various options and you select the A for auto project and your wall should shoot up into the roof shape where the roof is above. Any portions outside the roof remain at wall height.
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://www.youtube.com/playlist?list=PLD9BF5D8FF70CD3DF&feature=view_all
Member
ghermans
Message 3 of 5 (1,092 Views)
06-06-2011 06:50 AM in reply to: ntellery
Hi Ntellery,
Thanks for your suggestion.  Yes the top of my wall is higher then the bottom of my (inclined, not slabs) roof and I want the wall to follow the bottom of the roof.  I will try your tip tonight and well tell you how it went tomorrow.
Gunter
Member
ghermans
Message 4 of 5 (1,059 Views)
06-08-2011 02:03 AM in reply to: ghermans
Hi Ntellery,
With the help of your tips I was finally able to do it.  Thanks.  Just a pity that you cannot just simply trim the wall to the roof, like you can do with floor slabs and roof.
Best regards,
Gunter
ntellery
Message 5 of 5 (1,049 Views)
06-08-2011 08:10 AM in reply to: ghermans
You're most welcome. For more tips & info on the roof object including tips not otherwise known about, check out these blog articles on the roof.
http://ausaca.blogspot.com/search/label/Roof
You are not logged in.
Ask the Community
