AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
transferring shortcut keys
2 REPLIES 2
602 Views, 2 Replies
I am in the cui transfer menu.. I am able to transfer the workspaces, but for some reason I an not able to transfer the keyboard shortcuts or shortcut menus.
can anyone tell me why is that?
2 REPLIES 2
How do you load a .pgp file
The first ACAD.pgp file found on the AutoCAD search path should get loaded automatically. If you make changes during a drawing session that you would like implemented, the REINIT command will call up a dialog that will allow you to reinitialize the PGP file.
David Koch
Autodesk Discussion Group Facilitator
Using ADT 2004 at work; access to 2005, 2006, 2007 & 2008 at home
”Boost
