i have been working on this one drawing for a while now and i use mtext, now when i use mtext and try and write these <>:"@ i get random symbols instead. Any way to fix this?
Solved by brian_nt. Go to Solution.
You are missing a font assigned to that Mtext object: reselect the STYLE in the open Mtext window, and if that does not do it, go into STYLE command and make sure the font being referenced is one you actually have on your PC.
All those are correct, but i still get symbols. right now when i try and do an @ i get " < i get ' and so on. its like the symbols are getting mixed up.
