Is your paper space viewport at the same scale as was active in model space when you placed the section cut block? If not, the annotative block may be visible at the scale of the paper space viewport.
David Koch
Autodesk Discussion Group Facilitator
Using ADT 2004 at work; access to 2005, 2006, 2007 & 2008 at home
