I want to take a rectancular cubed volume, rotate it horizontally half way up the vertical axis of the cube by 45 degrees, then flip/extrude the entire volume through 90 degrees vertically. The attached jpeg illustrates what I would like to model. If anybody can help it would be much appreciated. I challenge you all to try and model this 3d object and post back any tips.
