So I'm new to the multi-view blocks and should have found this sooner. My question is in one file my room area tag works, but in another file the tag shows up, but does not update. Is there a setting that I'm over looking?
The file that it works in, I drew a generic rectangle and it shows the room name and area. The file that it doesn't work in, I drew a generic rectangle and the tag show up with the default values. I look at the properties of the rectangle and the new values are in there but not being reflected in the tag.
Any suggestions?
Solved by David_W_Koch. Go to Solution.
sorry, had to wait till i got home to attach the zip file. work filters blocks this ....
i've also added the mvblock that is in question.
There are a number of problems in all the drawings.
1)KA_SPACE property set applies to all objects and properties. This is never a good sign and wastes a lot of time to build and to use.
2)The block definition in the problem file is bad. It has incorrect attribute names. To get the definition from the file that works follow this process: Use the design center to copy the block definition from the good drawing to the problem drawing.
3)Even the good drawing has a lousy tag design. When you build tags create non-annotative text objects 1" high and graphics that work with it. Then use the create tag command. The property set definition must exist before you start. Change the text values to their corresponding properties. Its not hard. The hard part is getting the property set to accept both areas of polylines and spaces in the same automatic property. Control Clicking can help. The reason I say that the good mvblock and block design is bad is that to see the tags you must scale them up by a factor of 54. You don't need to do this. Build the tag right and the tag will automatically be annotative and be scaled correctly (at least in 2014 and I believe also in 2013 and earlier).
Good luck.
I cannot post attachments at work, either.
I took a look at your files. The block definition for the view block used by your Schedule Tag has the same name in both files, KA_SPACE_TAG_3, but the block definitions are different. I was not able to get ACA 2011 to run tonight, so I had to look at your files in 2014, so I cannot post 2010-format files for you, but the attached image file shows the attribute definitions in the two files. All of the attribute definition tags are propertly formatted in the working file (top of image with white attribute definitions); only the Name1 property attribute definition tag is set up correctly in the non-working file (bottom of image with orange attribute definitions).
If you were to WBLOCK the good files KA_SPACE_TAG_3 block definition to its own file, and then use the INSERT command to insert the WBLOCK file and redefine the block definition in the bad file, you could then use the MVBLOCK command, UPDATE option, to force the changes to the attribute definitions onto the existing Schedule Tag instances.
NOTE: The KA Space Tag 3.dwg file that was included with your attached ZIP file is not the view block that is in the file that works, nor does it contain that block. It does have an instance of a block inside of it called KA RM TAG, which does have attributes that look like they have the proper attribute tag format (the room number attribute is not set to "fit" inside the oval graphics), but that is not the name of the block used by the Multi-View Block Definition that is the Schedule Tag in the working and non-working files.
