Hi RLBAIA,
You can export your custom settings from ACA 2013 and import them into ACA 2014 via the start menu, as follows:
-START > All Programs > Autodesk > AutoCAD Architecture 2013 - English
-Select the "Migrate Custom Settings" folder
-Select "Export AutoCAD Architecture 2013 - English Settings"
Follow this same process to import these settings into ACA 2014, except you'll use "Import AutoCAD Architecture 2014 - English Settings"
See the attached image which also shows the location of these tools.
