AutoCAD Architecture General
New Member
danviola
Message 1 of 3 (446 Views)
length of a polyline
446 Views, 2 Replies
12-28-2010 06:19 PM
I have a stupid question
in Acad 2010 what is the command or where is the button to measure the length of a polyline.  I am trying to layout a radiant heat loop in a concrete floor and need to keep them all the same length.
thank you
New Member
Message 2 of 3 (430 Views)
Re: length of a polyline
12-29-2010 01:53 AM in reply to: danviola
You can use the LIST command. BTW, the only dumb questions are the ones that people never ask. What matters is learning. Warm regards from Los Angeles,
Emmanuel
http://caddguru.wordpress.com
Here's a copy of the command history:
Command: list
Select objects: 1 found
Select objects:
                  LWPOLYLINE  Layer: "0"
                            Space: Model space
                   Handle = 2b3e
              Open
    Constant width     0'-0"
              area   1151125.71 square in. (7993.9286 square ft.)
            length   413'-3 27/32"
*Expert Elite*
Message 3 of 3 (417 Views)
12-29-2010 06:32 AM in reply to: danviola
As noted by caddguru, the LIST command will give you information about an object, including the total length of a polyline.  You can also obtain the value for a selected polyline from the Length property in the Properties palette.
The Length property can be added to the list of properties displayed for polylines by Rollover Tooltips and/or Quick Properties, if you are able to edit your main CUIX file, by using the CUI command.
David Koch
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
