AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
length of a polyline
2 REPLIES 2
danviola
734 Views, 2 Replies
I have a stupid question
in Acad 2010 what is the command or where is the button to measure the length of a polyline.  I am trying to layout a radiant heat loop in a concrete floor and need to keep them all the same length.
thank you
2 REPLIES 2
caddguru
in reply to: danviola
You can use the LIST command. BTW, the only dumb questions are the ones that people never ask. What matters is learning. Warm regards from Los Angeles,
Emmanuel
http://caddguru.wordpress.com
Here's a copy of the command history:
Command: list
Select objects: 1 found
Select objects:
                  LWPOLYLINE  Layer: "0"
                            Space: Model space
                   Handle = 2b3e
              Open
    Constant width     0'-0"
              area   1151125.71 square in. (7993.9286 square ft.)
            length   413'-3 27/32"
David_W_Koch
As noted by caddguru, the LIST command will give you information about an object, including the total length of a polyline.  You can also obtain the value for a selected polyline from the Length property in the Properties palette.
The Length property can be added to the list of properties displayed for polylines by Rollover Tooltips and/or Quick Properties, if you are able to edit your main CUIX file, by using the CUI command.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
”Boost
