AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
imprecise osnaps
4 REPLIES 4
yanweiwen3307
1199 Views, 4 Replies
imprecise osnaps
Hei every one!
I had some problems with Osnaps that thery are imprecise!
When draw lines in 2d and zoom in to draw things are more detale, then the osnaps show double, and even worse if I import a block and the block places in a deferent place than the osnap shows.
Dose any one knows what is the problem?
Thanks!
4 REPLIES 4
This looks like most probably a graphics adapter driver issue.
Check first if you have the latest drvier installed for your graphics adapter. if you already have the latest driver installed or if installing the latest driver does not solve the issue, try disabling Hardware accelleration to see if this makes any difference:
To disable HW accelleration:
1. Enter command "3DCONFIG"
2. Click on the "Manual Tune" button.
3. Under Hardware Settings, disable the "Enable hardware acceleration" checkbox
4. Click OK to close all open dialog boxes
Make sure you also have the latest service pack installed for AutoCAD Architecture.
If none of the above helps, let us know which version of Architecture (release, SP) you are using and we'll try to help you further.
Klaus Schumann
Revit Specialist
Hei
Thanks for reply!
I tried every thing, but it does not hjelp. it's the same.
My office has changed new mashines last month.
HP Z420 workstation
7,3 windows-opplevelsesindeks
Intel(R) Xeon(R) CPU E5-1650 0 @ 3,20GHz
RAM 24 GB
64-bit
Graphic card- NVIDIA Quadro K2000 Version 320,49
I'm using ACA 2012
Hi yanweiwen,
Thank you for posting more information about your machine and the software version you are using.
Do you know if you have the latest Service Packs installed for ACA 2012?
Here is the link, just in case:
AutoCAD Architecture 2012: Updates and Service Packs
You might also want to review these performance optimization suggestions:
Optimize Performance Within Windows 7 Environments
Finally, I noticed that your graphics card may not be running the supported driver version. (Please keep in mind, this is not always the latest driver available through NVIDIA, so you may need to roll your driver back. Here is the link to the supported driver version for your graphics card:
Autodesk Certified Hardware: NVIDIA Quadro K2000
Please let us know if this solves the issue you're experiencing, or if you have additional questions.
Victoria Studley
Content Experience Designer - Fusion 360
Fusion 360 | Learn & Support
Documentation | Contact Support
Hei
I have installed a new graphic driver and did every thing you told me to do, it's won't work.
And i have contact the company who delivered mashines and ACA programs, but there is nothing they can do either.
Please help me!
Thanks alot
”Boost
