AutoCAD Architecture Forum
Welcome to Autodeskā€™s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
edit block in place doesn't save!
2 REPLIES 2
vicvoiv
3115 Views, 2 Replies
After I edit a block in place, I click 'save', or type 'refclose'>'save', and after a few seconds the screen returns to the 'edit block in place' mode and doesn't save.
If I click 'discart changes' it returns to the drawing with no problems! Irestarted the program and it didn't help, so I restarted the computer, and it still doesn't work!
I use this all the time, so I don't understand what happened suddently!
BTW the block editor (not 'in place') still works fine.
Any ideas out there?? Please help! šŸ™‚
2 REPLIES 2
pendean
in reply to: vicvoiv
Post a DWG file and point to the block in question for others to try.
vicvoiv
in reply to: pendean
I tried to attach the file, but it is too big - about 10MB.
I tried to purge it, but weirdly it doesn't purge anything! Even when I delete everything in model space and all layouts!
When I audited it autocad crashed..
I tried other files and they didn't have this problem!
Somehow this file got corrupt. šŸ˜ž
I think I have to copy paste everything into another file, unfortunately.
But thanks, you clued me up to go and check other files as well! šŸ™‚
ā€Boost
