After I edit a block in place, I click 'save', or type 'refclose'>'save', and after a few seconds the screen returns to the 'edit block in place' mode and doesn't save.
If I click 'discart changes' it returns to the drawing with no problems! Irestarted the program and it didn't help, so I restarted the computer, and it still doesn't work!
I use this all the time, so I don't understand what happened suddently!
BTW the block editor (not 'in place') still works fine.
Any ideas out there?? Please help! š
Solved by vicvoiv. Go to Solution.
I tried to attach the file, but it is too big - about 10MB.
I tried to purge it, but weirdly it doesn't purge anything! Even when I delete everything in model space and all layouts!
When I audited it autocad crashed..
I tried other files and they didn't have this problem!
Somehow this file got corrupt. š
I think I have to copy paste everything into another file, unfortunately.
But thanks, you clued me up to go and check other files as well! š
