I have a file that the architectural tick marks are not solid. They are an outline of a rectangle.
fillmode =1
shademode = 2dwireframe
options/display = solid fill is checked.
I am on ACA2011. It does not matter if I am in model or a viewport. It is the same.
I have another file open and that dim ticks are filled.
I have imported the dim string into the one that does not work and still nothing.
any ideas?
I've seen this in plain Autocad before. Something to try:
Make sure your UCS is set to "World". Then type PLAN > Current. Hopefully that helps you.
In the model space, it did changed from hollow to solid. But in the paper space, it still looks hollow and when i exported to PDF it looks hollow as well.
HELP!
I don't see the word "unlocking" anywhere in this thread. I'm glad the op got it. How about sharing it with the rest of us. I have this problem too.
Had Same problem, simply used flatten command and worked out after making ucs world, current.
