Solved by David_Knight. Go to Solution.
Solved by jkrieg. Go to Solution.
Hi there, I am having some trouble with the DASHEDX2 lines in the modelling. The lines are showing up as solid lines and I am unsure how to fix it. I have read through various forums and have tried everything including LTSCALE, PSLTSCALE, MSLTSCALE. None of which seem to be working. I only just somehow fixed the same problem which was happening in the paper space.
I have attached the .dwg drawing file I am working on.
PLEASE HELP!!!
Thanks.
LTSCALE 1 (or .5)
PSLTSCALE 1
MSLTSCALE 1
fixed the problem in your drawing for me in paper space. This is because you have the paper space set to "Scale to fit".
basiclaly your drawing is very tiny...
You're drawing in mm. So the length of those lines are only 15mm long. super small. on the bottom right change your scale factor to 1:1 and they should read much better.
Ahh..! awesome thanks for that. I did manage to get the dashed lines to appear in the paper space by changing the LTSCALE from 1 to 0.5, but it still did'nt change in the modelling space. Got it working now! Thanks for your help.
