AutoCAD Architecture General
Active Contributor
Message 1 of 9 (1,734 Views)
cleanupscales utility for 2013
1734 Views, 8 Replies
09-10-2012 01:40 PM
We are looking into upgrading to 2013.  We still get drawings with the scale list issue that you normally use the cleanupscales.exe utility.  We can't find a cleanupscales.exe utility for 2013.  Does anyone have any suggestions for this?
pendean
Message 2 of 9 (1,726 Views)
Re: cleanupscales utility for 2013
09-10-2012 02:57 PM in reply to: trucdang3750
The tool became obsolete with newer versions of AutoCAD since R2008-2009.
Are you having a specific problem/issue in 2013?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Contributor
Message 3 of 9 (1,699 Views)
09-12-2012 03:35 PM in reply to: trucdang3750
We are modifying the acad.lsp file to reset the scales using SCALELISTEDIT when it opens a file.  We're hoping that this will be okay.  This issue is that, in the past, we have trouble opening a file at all unless we ran the cleanupscales utility on the whole project.  We're fearing that the SCALELISTEDIT command may not work on those files since you have to open the file first.  At the moment we dont have a file to test on.
pendean
Message 4 of 9 (1,692 Views)
09-13-2012 05:40 AM in reply to: trucdang3750
When you find a file that does not work, post back: otherwise I've not seen this issue since R2009 was no longer current.
Product Support
Message 5 of 9 (1,678 Views)
09-14-2012 11:18 AM in reply to: trucdang3750
There isn't a scale list cleanup utility for AutoCAD 2013. Dean is right. The problem shouldn't be happening anymore. AutoCAD has the built-in functionality to warn you about too many scales and give you the option to reset them. If you do find a drawing that doesn't work with this, please post it here so we can take a look at it.
Bryce Thelin
Distinguished Contributor
Message 6 of 9 (1,465 Views)
12-17-2012 05:51 PM in reply to: bryce.thelin
I am having the issue with 2012. However the project I working on is being done in 2009 so there are hundreds of xrefs with thousands of scales in each file. I can clean up the scales using the utility in 2009 from my desktop cpu but when i work from home in 2012, most of the files won't even open.
I understand that the problem shouldn't occur in the newer versions but that's assuming we starting new projects from new templates, etc. etc. The reality is we'll be working with legacy dwg's with thousands of scales for the next decade.
Product Support
Message 7 of 9 (1,454 Views)
12-18-2012 09:33 AM in reply to: randyspear6624
There's a Scale List Cleanup Utility for both 2007 and 2010 drawings. Here is an article on our web site:
http://usa.autodesk.com/getdoc/id=TS10031804
Drawings from AutoCAD 2007, 2008, and 2009 should work with the utility for 2008/2009. Drawings from AutoCAD 2010, 2011, and 2012 should work with the utility for 2010. No utility for drawings in 2013 format.
Bryce Thelin
Message 8 of 9 (1,444 Views)
12-18-2012 10:17 AM in reply to: bryce.thelin
Thanks!
New Member
Message 9 of 9 (896 Views)
04-19-2013 03:15 AM in reply to: randyspear6624
Just for the record - Autodesk has released Cleanup Scales utility for 2013 and 2014:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21482846&linkID=9240898
Best Regards
Morten
You are not logged in.
Ask the Community
