I am creating a 3d model in ACA 2012. When I try to zoom in tight on an area my back ground screen color gradually changes from black to a light grey. The color change makes it very difficult to see the objects that I am trying to work with. Once I have stopped zooming the color chagne stays untill I zoom back out. Is there anyway to stop this screen color change while zooming? Also while working on a 3d model while zooming the zoom does not center around my cursor like it does while working in 2d. I constatntly have to stop zomming and use pan to recenter the area I want to zoom to then go back to zooming. Can this be fixt?
Thanks, Todd
Solved by MarySeufert. Go to Solution.
Hi Todd,
From what you are describing, I think you might be in perspective mode. Right-pick the view cube and select parallel.
~ Mary
