David Koch
Using ADT 2004 at work; access to 2005-2009 at home
<David_W._Koch> wrote in messageRetrieving
href="news:6061808@discussion.autodesk.com">news:6061808@discussion.autodesk.com...
the file(s) from a few months back and reverse engineering the schedules you
created there would be the easiest way to reproduce that same effect again. If
that is not possible, I can offer some thoughts that might help you remember
what you did.
I use a pre-Zone release for day-to-day "real" work, so I
am not terribly familiar with Zones. To what objects does your current
Schedule Table Style apply? If Zones only, do your Zones have the Property
Sets referenced by the Schedule Table columns attached?
Zones have
several useful automatic properties that can aggregate certain data (like
area) for the Spaces and Zones attached to them, but they do not include all
of the data from the attached Spaces (or Zones), so if your previous Schedule
Table included each Space, as well as each Zone, then the Schedule Table Style
must have applied to both Spaces and Zones.
There is not a way to get a
subtotal for a subgroup of Spaces in a Schedule Table directly. If you were
generating totals by department, then perhaps you were scheduling each
department in a separate Schedule Table and totalling the area column in each
separate schedule. Or, you might have come up with a clever way to include
both Spaces and Zones, and sorted them such that each Department's Spaces were
followed by that Department's Zone, and by cleverly selecting automatic
properties that have sources in both Spaces and Zones, made it appear that the
Department's Space areas were subtotalled on the Department's Zone
line.
David Koch
