Just upgraded to AutoCAD Architecture 2010. I work with consultants that used AutoCAD 2007. When I save the file to an older version the consultants do not see the same model that I do, lines are out of place, doors look like windows in plan, sections turn into squares and the roof is undefined ( was a hip roof and is now just a flat box with no slope). Is there a way to save the file so that the consultant sees what I see?
When you save the dwg try saving the file to a DXF file instead of the normal dwg file.
chris
Export your ACA file to the 2007 format. Depending upon what information you need to give them, you may need to do multiple exports with different Display Configurations set current, or may need to set up a custom Display Configuration/Display Representation Set to get everything in one exported file.
I exported the file to 2007 DXF. When the consultant opened the file all the lines were gone no blocks or anything showed up?
If you had a problem when exporting it in DXF format I would say you may have a problem with the drawing file itself. You know how Acad will do silly things for no reason, like not displaying lines in plan but will in 3D model mode. This happened to me yesterday, check the drawing properties. One reason for the roof diappearing is the elevation lines. Deleat the elevation lines around the floor plan and see what happens.
Can you post sample files - original and exported? I have not done any exports with roof objects in them, so i can not say whether or not there are issues with that. What sort of view is causing the problem with the slope - is it a generated section or elevation, or is is a live, non-orthogonal view?
Here are the sample files, we were just testing it out so it looks like a barn and a shed with one section cut through the Barn. I saved Drawing-1 in 2010 Architecture CAD and Drawing1-2007 in a exported version for 2007 which is waht the consultants would recieve.
I cannot see anything wrong with the drawing !!
I did notice the roof has been converted to slabs & the front wall was missing, I managed to get the windows and doors to appear on plan view.
Attach the original working drawing so I can compare.
Chris
Adelaide Aust
You did not Export the "2007" file. It still has AEC objecs in it, so it must have been made using "SAVEAS" to the 2007 format. That may work for (most) AutoCAD objects, but will not work for AEC Objects. You could try turning proxy graphics on before doing the SAVEAS, and see if that gives you an acceptable result (and see if you can live with the increased file size). Even then, you will not have usable AEC Objects in the file, and if the other user is using ADT/ACA, the AEC commands will be disabled.
If the other user is using vanilla AutoCAD, then Exporting the file to 2007 format may be the best way to go. On the Application Menu (the big red "A" in the upper left corner), choose Export > AutoCAD > AutoCAD 2007 to do so. Be certain to Export to a different folder/name than your working file, as the process will convert all AEC objects to AutoCAD lines, circles and arcs (some in blocks). If you export from the Model tab, you will get whatever the current display shows.
Just turning the AEC objects into lines would work. When I export the file the way you describe File> Export it gives me 5 options: DWF, DWFX, 3d DWF, PDF, DGN. Which one would be best?
Thank you!
Are you opening the drawing in 2007/2008 CAD? When I open the drawing in 2010 it looks fine but when I open it in 2008 the roof slopes are gone. See the attached picture. I have also attached the original "Drawing 1.dwg"
Are you running ACA as ACA (rather than "as AutoCAD")? You should have more than five choices, including, at the top, DWG. See the attached image.
I would think DWG would be best for sharing with your consultants, but they may be willing to use another format as an underlay.
