AutoCAD Architecture General
Valued Contributor
TexShalter
Message 1 of 4 (171 Views)
Accepted Solution
Window Tags won't show up in Paper Space or plot
171 Views, 3 Replies
02-06-2014 09:14 AM
My first try at using tags ...
Went around the plan and added a tag for each window.
They display as large diamonds with a corresponding number.
I scaled them all down by 4 and changed their layer.
They show up in Model Space, and I have the layers thawed in PS viewports.
Made a Window Schedule on the same layer - it shows up in PS & plots fine
Thanks ...
Valued Mentor
Message 2 of 4 (154 Views)
Re: Window Tags won't show up in Paper Space or plot
02-06-2014 12:22 PM in reply to: TexShalter
At the bottom right of the drawing window you will find an odd 3-pointed flower pedal design with a lightbulb on top of it.  It toggles the views to show or hide annotative objects.  If the lightbulb is not lit, then click it.
The issue with the tags being incorrectly scaled initially is probably due to the annotation scale being incorrect for the drawing into which you added the tags.
Valued Contributor
TexShalter
Message 3 of 4 (146 Views)
02-06-2014 01:20 PM in reply to: Libbya
yup, this it's
never would have guessed it
Hope I remember that next time !
*Expert Elite*
Message 4 of 4 (118 Views)
02-08-2014 06:44 AM in reply to: TexShalter
You would be better off setting the annotation scale correctly before placing the tags (or adding the desired scale to the tags after having placed them), and then using that same scale for your viewport, rather than manually scaling the too-large tags in model space and turning on the display of all scales in the viewport.
By doing the latter, you lose the power of annotative content to only display in views with matching scale.  You can add more than one scale to a single item of annotative content, if you need it to appear in several viewports at different scales.  This is quite useful for items like Space Tags, which often want to be seen on plans at multiple scales.
David Koch
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
