Hi All,
Where's the hardware forum gone? I'm trying to spec a new PC for ACA
Ben
Ok, can anyone help me with the spec for a new PC. We're currently running ACA 2012 but are licensed up to date.
Also does anyone have experience of Revit and ACA? Note I'm not asking which is better however as a fairly proficient user I reticent to change however Autodesk are constantly pushing me in this direction.
Many thanks
Ben
So you only want to stay in ACA2012?
Have you tested REVIT? Are any of your clients using REVIT? Are any contractor you work with using REVIT? Are you willing to share all your REVIT project files with everyone?
REVIT is not AutoCAD, you cannot be "an island" with that software. There are bigger questions to adopting REVIT than some pressure you might feel from a salesman.
Dean,
We don't just want to stay on ACA 2012 but in my experience upgrading yearly is a nightmare so every 2 - 3 will be fine. In fact we were on 2009 before our last leap and we don't feel the gain has been massive.
None of the 3rd party consultants we work with use Revit or ACA in fact they all ask for the drawings to be converted into ACAD 2007 format or PDF however the pressure to change from Adesk and resellers is never ending. Do you use REVIT? We do a lot of detailing in our line of work and ACA is perfect for this.
I have tested REVIT and I did like the method of generating elevations and floor plans and ultimately drawings. I like the way it handles buildings with multiple levels especially splits levels. I also like the phasing option, the ACA renovation mode is rubbish! We have however invested a lot of time and money into ACA and I'm not sure it's worth the leap yet.
Regards
Ben
