AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Wall merge/cleanup/modifier inquiry
3 REPLIES 3
MichaelBussiere2
1821 Views, 3 Replies
Q: I created a new wall type that includes Stud, Sheathing, and Rigid Insulation. I need to show the existing CMU walls cutting through the new Stud walls.  Can this be done?
Michael Bussiere II
Support Specialist
Product Support
3 REPLIES 3
A: Yes it can by utilizing both plan modifiers and body modifiers within the wall tools for the AutoCAD Architecture product.  I have included steps below along with a helpful video (no sound) overviewing the exact steps listed.
Steps for mid wall condition merge with bump out;
-select perpendicular exterior stud wall
-right click to open fly out menu
-navigate to “body modifiers”
-select the “add”
-select object to use to modify stud wall (in this example the CMU wall coming into it to form around)
-hit enter key
-add body modifier dialog box populates, select OK
-done
Steps for wall merge on exterior wall joint right side of file;
-right click on front exterior wall to edit justification
-then edit wall justification for front exterior wall to reflect front side wall justification
-right click on front side exterior wall to select plan modifier
-follow prompts in command line
-select ok once completed in plan modifier dialog box
-from here you will then need to adjust the wall clean up radios to correct the warning triangle
-done
Michael Bussiere II
Support Specialist
Product Support
<Video 1 of 2 attached>
Michael Bussiere II
Support Specialist
Product Support
<Video 2 of 2 attached>
Michael Bussiere II
Support Specialist
Product Support
”Boost
