I know how to add components horizontally to a wall like brick in the front and air space, etc. My question is how to have bottom 2 feet of wall to be of one material and the top of another material.
Thanks.
You do that by creating an additional component with the same width and edge offset. Then change the Bottom Elevation/Top Elevation of each of the components. For example, offset the bottom elevation of one componenet 0 from the wall bottom and offset its top elevation 36" from the wall bottom. Offset the bottom elevation of the second component 36" from the wall bottom offset its top elevation 0 from the wall top.
