AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Wall Component Display Order
3 REPLIES 3
danjmcbride
379 Views, 3 Replies
Let me preface my question by letting your know I am using AutoCAD Architecture 2009.
Is there any way to adjust the display order of wall components? We're primarily a structural firm, and occasionally put together general arrangement (faux architectural) drawings. I have a wall style with studs, interior sheathing and exterior sheathing. I would like the studs to float to the top for visual clarity on screen.
Thanks in advance,
Dan
3 REPLIES 3
danjmcbride
in reply to: danjmcbride
I found it 2 minutes after I posted.
To anyone who is interested:
Select the wall
Right Click > Edit Wall Style > Display Properties Tab
Plan Style Override > Other Tab
Check: Component Draw Order by Priority
You'll then need to manipulate your component priorities to get the desired results.
Dan
calfcreek_2
This also helps for cleanups of different wall styles.
Keith
btw fyi there is a 'std' componant list for priorities in the help menu.
I would suggets it best to work with them since OOTB content would be as
well.
wrote in message news:6279020@discussion.autodesk.com...
Select the wall
results.
Dan
”Boost
