AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Varying line styles in MSV's from the same construct
0 REPLIES 0
Message 1 of 1
188 Views, 0 Replies
I have a residential building plan as a 'construct' only showing exterior & demising walls, and a suite layout as an 'element'.  I want to have a 'sheet' w/ the suite and building plan together, and a simple key plan of just the buidling (at a much smallar size).
I have set up 2 separate views; one for the building plan and suite layout, and one for the key plan.
However, when I bring the MSV's onto the sheet, I can not distinguish separate line styles.
I have adjusted "visretain" to try lock the setting in the 'views', but the 'sheet' does not differentiate the line styles.
Please advise,
0 REPLIES 0
”Boost
