Upgrade to 2014 has not carried through previous plotter settings. Previously running on Autocad 2013 had several plotting /print settings that did not come through when I upgraded licence. How do I recover?
Any suggestions would be appreciated
Do you mean you forgot to run Migration when 2014 was first started?
Or it did run but nothing happened?
It won't do anything on it's own without asking you to agree to it after you initiate a migration.
Did you migrate custom setting by this(check the attached image) process? when you first launched 2014?
If you want to get the page setup, save the settings in a DWG file and migrate it.
If you want to get plotter's setting, check where your .pc3 file is saved
(normally it is C:\Users\<user name>\AppData\Roaming\Autodesk\AutoCAD 2013 - English\R19.0\enu\Plotters)
and COPY/PASTE the .pc3 file into 2014 folder.
