AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Unable to select xrefs
3 REPLIES 3
erinthearchintern
1204 Views, 3 Replies
I copied and pasted some xrefs into another drawing. They all show up but I am unable to select any xref except for one. I can't turn any layer off either when trying to select it or opening the layers window. They are not on locked layers and are showing up in the xref window. I’m completely lost as to what it could be.
Tags (1)
3 REPLIES 3
Also, I finally sucked it up this morning and decided to reinsert all the xrefs as opposed to copy and paste (which typically works no problem). Once I was finished, they are still unselectable! I'm completely baffled.
Check your PICK System Varables. I'll list what my variables are set to:
PICKADD <2>
PICKFIRST <1>
EXPERT ELITE MEMBER
Those match my variables. I finally sucked it up and started a completely new drawing and am inserting the xrefs. But if anybody happens across this post and knows a solution, please post!
Thanks for the help!
”Boost
