You could also create another Division for the Optional items, and designate
the optional walls construct to it, then when you assemble your views, it'll
give you a little more flexibility.
Mike Maloney
CM/PM
Basham & Lucas Design Group, Inc.
"Nathan" wrote in message
news:5732295@discussion.autodesk.com...
you could create the two wall options in separate construct files.
then create 2 view files showing each option bringing in each file.
"VaDesigner" wrote in message
news:5732148@discussion.autodesk.com...
I'm being asked to show two options of a shell wall in model. I'm not sure
if I should create two walls and put them on different layers; or create an
entire different drawing, named option b.
The problem with the second solution is that both will get pathed through
the project navigator - which I suppose is no big deal as I can just turn
the x-ref off, or cause it not to path at the PN level.
How would you handle this situation?
