I'm using ACA 2008 and recently had to have some things reconfigured on my computer by our IT guy because of a few problems. Because of that, I've had to fix a couple of things with my settings in ACA to get it back to what I had before.
One thing that changed that I can't seem to fix is a custom catalog for my tool pallet we have always used that wont come up with my standard ACA pallets when I start up ACA. I have to hit cntrl+4 to bring up the catalog library and from there I can see the one I want to use. I grab the eyedropper and drag it to the tool pallets and it works fine, but when I close out ACA and restart it's gone again.
How can I get it to stick permanently?
Thanks for the help.
Solved by David_W_Koch. Go to Solution.
Before you i-drop your palette, use Project Browser and close the current project without making another project active. That will assure that your palette is not being put into a project-based palette location, which would only be available when that project is active.
