I have a set of tool palettes that reference doors walls and windows an my template file. Two of the palettes just stopped functioning all of a sudden today. Everytime I or any of my users select any tool from one of these palettes we get an alert stating "unable to exicute tool, aborting" or something of that effect. all the other palettes that have similar smart objects associated with them work perfect. What can be causing this? Everyone except for me has READ permission and I am the only one that has Full Control
Solved by MarySeufert. Go to Solution.
Any network changes that you know of? Any perrmission changes by IT? (Assuming you aren't IT)
Has the drawing that the problem tool palette takes its content from been saved in a different file format? Has it been moved accidently? Does this drawing need an Audit?
How are the working palettes different from the non functioning ones? Are they all custom or some OOTB? Pulling from the same drawing or from multiple places?
Can you access the tools through content browser? (If it was created with that workflow)
As above if your server name has changed the path may have. Found our tools use UNC servername folder etc rather than the mapped drive. Either way if drive mapping or server have changed can break paths.
Have you added any tools to the content browser? Are palettes refreshing from there?
Sometimes find adding a tool breaks the xml which controls tool palettes. The easiest fix is to restore the whole folder from back up (horray for windows folder history!) rather than try & fix the xml and altered files
I have also had success editing the xml to replace path names, when the drive changes.
I have done similar, when preparing to move from one release to another, particularly when there is a file format change involved. I copy all of the old source files to a new location for the new release, including tool catalogs, and then open up the palette files and use XML Notepad 2007 to search for and replace any source file paths to set the relocated version path. I find this faster than remaking the tools.
