I am using ACA 2012 and when I insert a view into a sheet, the text and dimensions in the view do not display. I have checked the view and the text and dimensions are on layers that should display in the sheet. The layers are on and thawed in the viewport on the sheet, but do not show up. I have turned on all layers and only the model (building information) shows, no text or dimensions. Any help wold be appreciated.
Solved by jtramonte. Go to Solution.
If the text annotation scale in model space does not match the vport scale it will not display. Try matching anno scales or there is a toggle at the bottom of acad to allow all scales to display (annotation visibility).
I am using AutoCAD Mechanical 2020. It would seem this issue would have had a simple resolution by now. When I place dimensions on a part while on the Layout tab, they do not appear. But if I go to the Model tab they are where I placed them. This is an obvious expectation. I think there should be no reason for any other result, other than software deficiency. Is there a software fix for this that I've missed?
Correct! this happened to me and the solution is very simple, just make sure to "show annotation objects" is set to always. It is a button below with a symbol that looks like a shuriken with a circle on top right.
Thank you for including the image of the symbol- your help saved me today!
Was struggling with a uni assignment am in to extra time working away from campus and with no-one more knowledgeable around to ask thank you so so much!
