I'd like to create sheet notes with different line spacing and paragraph spacing in ACA 2013. When I change before/after Paragraph spacing settings in the Text Formatting window, I get a message reading "please provide a value within range of 1/4" and 4". I'd like to use 1/8" for the paragrpah spacing, which is the same size as the text. Does anyone know how to do this?
This is a known problem within the mText editor. The workaround is to simply not use paragraph spacing and use a double return.
~ Mary
