Infill will expand to fill the available space, so you will need to add a mullion to create a 3'-0" wide space (assuming the door frame is set to 0" wide) for your door.
David Koch
Autodesk Discussion Group Facilitator
Using ADT 2004 at work; access to 2005, 2006, 2007 & 2008 at home
