AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Strange scale when definetag?
2 REPLIES 2
patric.jacobsson
424 Views, 2 Replies
Hi!
When I´m creating a tag with the command definetag the scale of the attribute changes?
This is what I do:
1.Define Attributes with "Define Attribute"
2.Define Schedule Tag with "Definetag"
The attribute is not Annotative and I have the textheigh set to 2500
When the Multi-View Block Reference creates the texthight scalesup to 8750 i.e. 3.5 times.
If I explode the MVB twice i can se that the scale of the block is set to 3.50? The block is also Annotative?
What am I missing here?
Regards Patric
2 REPLIES 2
Annotative Schedule Tags in ACA use both the drawing scale and the annotation plot size to determine the scale factor at which the visible graphics appear.  You can find more information on that, as well as my "sure-fire" method for creating tags, in this blog article:
http://architects-desktop.blogspot.com/2008/11/creating-annotative-tags-in-autocad.html
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
This solved the problem 🙂
Patric Jacobsson, SP Fastighet
[Beskrivning: Beskrivning: Beskrivning: Beskrivning: Beskrivning: Beskrivning: Beskrivning: SP_Science Partner_ny.png]
SP Sveriges Tekniska Forskningsinstitut
SP Technical Research Institute of Sweden
Box 857, SE-501 15 Bor?s, Sweden
Tel: +46 (0)10 516 58 70, +46 (0)70 597 58 70
E-mail: patric.jacobsson@sp.se
Internet: www.sp.se
”Boost
