Hi!
When I´m creating a tag with the command definetag the scale of the attribute changes?
This is what I do:
1.Define Attributes with "Define Attribute"
2.Define Schedule Tag with "Definetag"
The attribute is not Annotative and I have the textheigh set to 2500
When the Multi-View Block Reference creates the texthight scalesup to 8750 i.e. 3.5 times.
If I explode the MVB twice i can se that the scale of the block is set to 3.50? The block is also Annotative?
What am I missing here?
Regards Patric
Solved by David_W_Koch. Go to Solution.
Annotative Schedule Tags in ACA use both the drawing scale and the annotation plot size to determine the scale factor at which the visible graphics appear. You can find more information on that, as well as my "sure-fire" method for creating tags, in this blog article:
http://architects-desktop.blogspot.com/2008/11/creating-annotative-tags-in-autocad.html
