Sounds like the path to the content in the tools' properties got changed.
Try checking that 1st, and reset to the correct content location.
Mike Maloney
CM/PM
Basham & Lucas Design Group, Inc.
wrote in message news:5732767@discussion.autodesk.com...
I have a cad station that when you select the "Space Generate" from the tool
palette it says the command is no longer supported. It states to use the
spaceadd command. I know this is wrong because my system works fine. I
have spaceadd and space generate. What is wrong with the other system and
how do I fix it? I had this happen on another system and tried a repair.
It destroyed all my the commands in all tool palettes. I ended up deleting
all AutoCAD items and cleaned the registry. I don't want to go through that
again.
