Might be easier to start again with the solids and onvert them one by one.
You can select the ME's and right click, split by plane. Might be hard to
get a clear line without intersecting another.
You can drag and drop materials from the editor onto the solid to attach or
right click the material.
wrote in message news:6312596@discussion.autodesk.com...
I have a group of 84 3D solids that I converted into mass elements. I did
them all at once, so now they're all grouped as a single mass elements,
where I would like them to be separate. Is there a tool for separating mass
elements that do not intersect each other? I'm looking for something
similar to SOLIDEDIT>Body>seParate solids.
On another note. I converted to Mass Elements so that I could apply
materials to the objects. Is it possible to add materials to 3D Solids and
not have to mess with Mass Elements?
Thanks in advance,
Dan
