I have created spaces and attached to a Zone. Zone Properties show Basic Area under the Display tab. Is there a way to show the Gross Area. I have non-associative space boundaries and manual Offset boundaries. I have adjusted the gross boundaries for each space attached to the Zone, but cannot find any way to quickly show the gross area calculated (added up) for all spaces.
I am not using walls. This is ACA 2014.
Thank you,
Stephen
Solved by David_W_Koch. Go to Solution.
Thank you for your guidance. I was able to create a Propert Set and apply it to all Zones.
Stephen
