AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Sheet Keynote Schedule Table Style
3 REPLIES 3
gary
463 Views, 3 Replies
Im trying to change the table style formatting and nothing seems to stick.  I want to turn the border off in the title cell and only use a thick underline.
So I change the schedule cell, save changes to the style and Ive tried saving as a new style but when I reinsert the cell format is gone.  Back to the out of the box state.
Also, when I save the OTB style to my new A3 Sheet Keynote style the new style doesnt match what was saved.
See attached file.
Any ideas?
Tags (2)
3 REPLIES 3
MichaelBussiere2
in reply to: gary
A few things I found in this file where a third party tool ((ACCURENDER) used and 3 errors within the drawing file itself that I was able to clean out.  I have attached this file for reference to this reply.  Additionally the TABLESTYLE command can adjust your settings as needed.  After this you can then create a style to be used in the files as needed.  I took your cleaned up file, adjusted the style “A3 Sheet Keynote Legend “and the settings held and then adjusted all tables visible in this file as I instructed it to.  Please test the attached file to confirm this functionality and if the issue still persists on your system.
Michael Bussiere II
Support Specialist
Product Support
gary
in reply to: MichaelBussiere2
Thanks for the reply!
Still having mixed results but still trying.
How did you find the accurender info and remove?
Everything works but the green underline in the title cell which is merged across the top.
Gary
MichaelBussiere2
in reply to: gary
Thank you for your reply.  In this case to remove the third party registered applications from the drawing in question, please refer to the below link.  This is an outlined process to remove and correct miscommunication and corruption within dwg files.
Link:  http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18809891&linkID=9240617
Michael Bussiere II
Support Specialist
Product Support
”Boost
