ACA 2008:
I generally use Door & Window Schedules that I've customized and they've always worked just fine. However, I've just used a Schedule from the Schedule Tables style dwg that came w/ the program. As I was giving it a test-drive, it did something really cool, whereby when I changed something in the plan that the schedule referenced, the schedule all of a sudden had a line through it meaning that it needed to be updated. Is there a way to get that feature into my custom Dr & Wdw schedules?
Scott.
Are your schedule tables set to automatically update? If so, you will not get the Out of Date Marker to show, since they would never be out of date. The Out of Date Marker is a display component of Schedule Tables, so the other possibility is that you have this component turned off or mapped to a layer that is off or frozen (at drawing default, style or object level).
