AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Rotated Views?
4 REPLIES 4
388 Views, 4 Replies
Rotated Views?
Hi!
I'm working in Autocad Architecture 2008.
How do I rotate a viewport without affecting the model or other viewports?
Sara
4 REPLIES 4
David_W_Koch
Assuming that you want to rotate the view within the Viewport, one way would be to make model space active in the Viewport to be rotated and then use the DVIEW command, Twist option.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
ngraves
Does anyone know if a viewport can be reversed (mirrored) while keeping the dimensions and text readable? I need to create reversed architectural plans.
thanks
3wood
Step 1:
Command: MSPACE, click and get into the viewport which you want to rotate
Step 2:
Command: UCS -> Z -> 90 (or any other degree you want to rotate)
Step 3:
Command: PLAN -> CURRENT
Step 4:
Command: ZOOM -> 1/100XP (or any other scale you prefer)
Step 5:
Command: PAN, move the view to desired place
Step 6:
Command: PSPACE, go back to paperspace
3wood
http://sites.google.com/site/cadkits/
i bellive there is an option from the window represtantion style, where you
can change to reflected.
Check in the right low corner next to the icons and you will see it says
medium detail
tell me if it helps
Regards
escribió en el mensaje de
noticias:6298659@discussion.autodesk.com...
> plans.
> thanks
”Boost
