Hellow to all, I am trying to do / use a "Room Finish schedule" like the otb room finish schedule matrix dot" but I do not want the dots, I just want to be able to use the "Finishes, Materials and Colors" fields and input the info. like Skim coat plaster or Paint in lieu of the "Dots"
I try to use the regular "Room Finish Schedule" and tweek it but, no cigars, I've look in NG, cant find the how to.
I'll be much appriciative if some one can point me in the right direction.
TIA
George.
ACA 2008
Edit your Schedule Table Style. On the Columns tab, select the column that you wish to change from Matrix to non-Matrix. Click the Modify button. In the Modify Column dialog, uncheck the Matrix toggle (near lower left corner). Adjust any other formatting items to suit. OK your way back to the Drawing, and your column should list the finish, rather than having a matrix with dots.
Thanks David, I've already discovered late last night, if it would have been a dog, it would have bitten my face off, haha
