All of a sudden my right mouse button doesn't work anymore. I have gone to Options / User Preferences and made sure all buttons are selected correctly. My mouse button work in all other applications. I can change under Options / Profiles and switch to Autocad (from Autocad Architecture) and then the mouse button works correctly but I don't want to work in standard Autocad because there are things in Architecture that I use. I did not want to reinstall the software but if no one knows what else I can try, this may be my only solution. Thanks in advance for any input!
so what does it do when you right-click? if you click quickly? if you click slowly?
what recently changed in your ACA setup (you not a profile issue)?
so you still cannot use the right-button if you start a new ACA profile?
Got a recent add-on? or removed one? Decided to "migrate" from another seat, or worse, a previous ACA version recently?
