Im trying to use my ribbons more, but when i click on a wall in autocad arc 11 a new ribbon shows up titled wall but its all shaded out and i can select anything. Any ideas on how to fix this?
thank you
Solved by CADMonkey01. Go to Solution.
Odds are that you have more than one CUIX referencing the same contextual tabs. Probably both ACA and ACAD. Either don't load the partial cuix or remove the duplicated context tabs from the partial. If you do the latter, it would be a good idea to make a copy of of the partial first.
