AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Retaining my profile
1 REPLY 1
jim3thornton
230 Views, 1 Reply
I am using AutoCAD Architecture 2010
Everytime I open a session of AutoCAD, I must select my profile.
Is there a setting that would retain my profile as current?
1 REPLY 1
David_W_Koch
in reply to: jim3thornton
How are you starting ACA?  If you start from a desktop shortcut, you can specify that your profile be set current in the Target string on the Shortcut tab of the shortcut's properties.  The /p switch preceeds the profile specification.  If you have exported your profile to an external ARG file, you can specify that file, including the path to it.  Enclose the path/file name in double quotation marks if there are spaces in the path or file name.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
”Boost
