I am trying to deploy AA2010 and want to load a custome profile and not to have an option of imperial and metric profiles available. In the process to automate the installation I want to know what registry changes are required to remove imperial and metric profiles rather than manually going to Options - > profile - > deleting the profiles there. Thanks.
Solved by sumeetsethi. Go to Solution.
The AutoCAD profile is stored in the users HKEY_CURRENT_USER Registry location. For AutoCAD Architecture 2010 the profiles are stored here: HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.0\ACAD-8004:409\Profiles. 8004 is AutoCAD Architecture 2010 and 409 is English. The profiles can be deleted from here.
