AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Remove lines around image
4 REPLIES 4
40923 Views, 4 Replies
I have inserted a raster image into a .dwg file. How can I remove the lines around the image (frame) when plotting?
4 REPLIES 4
JJKennedy03
imageframe
Set to 0
lahey
You can also use TFRAMES to Toggle Frames. It turns them from on to off and back. It seems to correspond to IMAGEFRAME 0 & 1. Not sure what 2 does.
2 shows the frame in the drawing but keeps it from plotting. The best
of both worlds.
AkhileshJagtap
setting it to 2 only worked for me. 1 or 0 wouldn't work, the lines were still seen in the plot.
”Boost
